RC3 Soft Fork
Another issue I had on testnet, that worries me a bit... is that I had 100k tDRKs, and I send just a few tDRK out ... and even with excess funds it touched my tMasternode 1k deposit.
Are you saying some of the 1k DRK you deposited for a masternode was used in a transaction and messed up your masternode setup?
If that is the case you need to enable the "Coin Control" options in your client. It allows you to select which inputs you use to make transactions. Make sure you deselect the address with the 1,000.00 DRK for your masternode. That way it won't get messed with. Alternatively, you can generate a new, "cold storage" address and use it. Save the private key somewhere secure. Whenever you finally decide to spend/move the 1k DRK you can import the priv. key into your client and use it like any other address...
The DRK Lord
The DRK Lord
Wow, I have not noticed 'Coin control' options, because I use cli.
Thank you ^^ DRKLord.
ref:
https://bitcointalk.org/index.php?topic=144331.0
I have tried to make a simple python scripts to send earnings.
I will but not soon.
The DRK Lord
Precisely. Will have to look into in better! Mind having a look anyway at my issue?
https://darkcointalk.org/threads/rc3-prelaunch-testing.1523/page-7#post-9820
This was standard procedure from long ago, I just stuck to it. Maybe I need to review my 1k funding procedure?
EDIT: just saw chaeplin's post. Also on CLI, but will read up on it.
Hey guys, i'm having a strange "problem":
i got new ip address from ISP. so i move my Maternodes from old IP address to new ones. (in the main net not test net). I don't change any setting which is working perfect well on the old ip except the LOCAL config file that point to the new REMOTE masternode ip address. In President's Masternode list, some of my Masternode shows in new ip address, some shows in old address. Even strange is that: one of my masternode should be showed in NEW IP address but not. It got paid still.....
All of my masternode version are: 10.11.4 (i will update today to 10.11.5)
My question is: should i need to generate new privkey when i change new ip address?
Thanks in advanced.
This maybe related to know bug #7 - the caching of IP/pubkey entries was to agressive and led to problems when reusing old masternodeprivkey with new IP. I don't know if Evan already sorted that out to the fullest, but as not all masternodes/pools have updated to 0.x.11.5 yet, the masternodelist still gets polluted by old entries.
So to answer your question: Yes, new IP --> new masternodeprivkey to avoid caching problems in network.
as I have had a couple of node 'misbehaving' for no apparent reason, I did generate a new key.. but I still have a problem. My own node said I misbehaved.
Use case:
Node is marked as misbehaving
stop node, stop EC2
start ec2 and retrieve new IP
edit conf file with new IP
start masternode.. still misbehavs
generate new key, edit conf file with new key
stop darkcoind, start darkcoind
start masternode..
results:
2014-06-27 00:30:29 ThreadRPCServer method=masternode
2014-06-27 00:30:29 CDarkSendPool::RegisterAsMasterNode() - Checking inbound con
nection to '54.203.70.151:9999'
2014-06-27 00:30:29 trying connection 54.203.70.151:9999 lastseen=0.0days
2014-06-27 00:30:29 connected 54.203.70.151:9999
2014-06-27 00:30:29 send version message: version 70018, blocks=92286, us=54.203
.70.151:9999, them=54.203.70.151:9999, peer=9
2014-06-27 00:30:29 Found unspent output equal to nValue
2014-06-27 00:30:29 accepted connection 54.203.70.151:47337
2014-06-27 00:30:29 CDarkSendPool::RegisterAsMasterNode() - Is capable master no
de!
2014-06-27 00:30:29 Misbehaving: 54.203.70.151:9999 (0 -> 1)
2014-06-27 00:30:29 ProcessMessage(dsee, 249 bytes) FAILED
2014-06-27 00:30:29 connected to self at 54.203.70.151:47337, disconnecting
2014-06-27 00:30:29 disconnecting node 54.203.70.151:47337
2014-06-27 00:30:29 socket closed
2014-06-27 00:30:29 disconnecting node 54.203.70.151:9999
Before the second fork attempt, I converted my hot running nodes to cold nodes. First one worked no problems.
But the other two had problems. They launched fine, and showed correctly on the masternode pages. But then they shortly showed as unlisted.
I managed to fix them by getting them new IP's (if on EC2 restart them)......be SURE to change your IP in the darkcoind.conf file. I also made a new wallet and sent the 1000DRK over.
So new IP, and new wallet address. Touch wood, have been running okay since. Your problem might be different not sure, I seemed to be banned either by IP or wallet address. Getting new on both did the trick.
Hey eduffield , just with the new x.x.5 release, I'm just wondering if you can let us know what errors we can expect in the logs (and should just ignore) and which ones we shouldn't.
This is what I'm seeing right now
2014-06-27 04:24:45 peer=82 says we are misbehaving 20
2014-06-27 04:24:53 ResendWalletTransactions()
2014-06-27 04:25:17 AcceptToMemoryPool: 98.249.39.67:57037 /Satoshi:0.9.11.5/ : accepted 0853eacc92ce9ab2c9836e19e4df13699300fa5b5a51f080ee1501944dd670bd (poolsz 5)
2014-06-27 04:25:27 ProcessMessage(dseep, 116 bytes) FAILED
2014-06-27 04:25:29 DarkSendStatusUpdate - state: 2 entriesCount: 0 accepted: -1
2014-06-27 04:25:29 received block 00000000000225652095ce737f6699d37f50209ab25703e724d53443bf3703d8 peer=1
2014-06-27 04:25:29 Committing 391 changed transactions to coin database...
2014-06-27 04:25:29 SetBestChain: new best=00000000000225652095ce737f6699d37f50209ab25703e724d53443bf3703d8  height=92378  log2_work=58.694145  tx=406010  date=2014-06-27 04:24:49 progress=0.999999
2014-06-27 04:25:29 ERROR: CTxMemPool::acceptableInputs() : inputs already spent
2014-06-27 04:25:29 CDarkSendPool::NewBlock - Is Masternode, resetting
2014-06-27 04:25:30 ProcessBlock: ACCEPTED
2014-06-27 04:26:28 getblocks -1 to 0 limit 500 peer=84
2014-06-27 04:27:48 dsee - Got NEW masternode entry 54.244.103.227:9999
2014-06-27 04:27:48 ERROR: CTxMemPool::acceptableInputs() : inputs already spent
2014-06-27 04:27:48 dsee - Rejected masternode entry
I'm assuming the imputs already spend for 54.244.103.227:9999 (not mine) means the Dark has been moved off? Just wondering if the above looks good. Cheers Evan
I noticed two of my masternodes got payments at 9am, but nothing since. Show correctly on the MN pages though.
Hey this may be a very stupid question but anyway.
If I start a normal client on a windows machine with my masternode wallet that contains the 1000 DRK plus the extra DRK i have earned from the payments, will that interfer with the masternode? lets say the config on the windows machine is default and I'm using the -qt version.
Follow up on that, if I have 1003.32 DRK in that wallet and send 3 DRK to someone, how will that affect the masternode? Lets say it stays above 1000 DRK.
Basically what I'm asking, can I send the excess DRK from the wallet without affecting the masternode in any way? And can I start the gui wallet on another machine at the same time.
Thanks all!
Hi flare chaeplin .
Thanks in advanced.
I've updated all my MN to New IP and New Prive key with version 10.11.5.
most of the MN are working smooth and perfect. but here is my problem:
one of my masternode with ip (xxx.xxx .xxx.166) which setup and running well (its old IP was xxx.xxx.xxx.198). but it showed on Presiden's Masternode list as 198. and it's 166 on elbzo.net.
i've repeat several time to setup this MN and everytime with new generated privkey. i'm preety sure all the operations are correct. and everytime i got the massage from both Local/Remot :successfully started masternode
So did i make some mistake or it's just cache problem? and the only thing is waiting? (i've waiting about 8 hours since MN setup.)
