Not yet, still trying to get hold of a Windows bug, but getting close.So, can we put DASH in Trezor yet?
And beside that, is it working?
I might have to go to Prague. Trezor and CZ... Bucket list, approved.
Wanted: waterproof trezor, because sailboat.
You can't start a 12.0 masternode with Electrum/Trezor, only 12.1 masternodes support it - it's a limitation of the current protocol.what about Trezor and MNs that are hosted remotely?
Also, will any trezor model will work with 12.1?
Thanks @flare. I meant is there a special type of Trezor model that i need to get to support dash? I think the answer is no.You can't start a 12.0 masternode with Electrum/Trezor, only 12.1 masternodes support it - it's a limitation of the current protocol.
Not sure what you are refering to with "12.1". If you mean "will Dash Core 12.1 support Trezor?" then the answer is no. You'll need to use one of these wallets which have HW wallet support.
Electrum-Dash 2.6.4 will be available soon, Mycelium integration is being worked on.
--> http://doc.satoshilabs.com/trezor-apps/index.html
Thanks @flare. I meant is there a special type of Trezor model that i need to get to support dash? I think the answer is no.?
Will you be creating an you-tube idiots guide to setting up Trezor with dash whenever 12.1 is released?
yes, that would be much appreciated. Also, does it have to be electrum wallet? Can i just use regular Dash client?No special type of Trezor, just the latest firmware (1.3.6) is needed for Dash support. What's nice about Trezor and KeepKey: You can use the same device for BTC and DASH in parallel. So using Trezor with Electrum will show you your BTC balance, while using the same Trezor with Electrum-Dash will show your DASH balance.
If you want to listen to my wonderful voice: Sure, why not![]()
Can i still remotely host masternodes?
messages, the latter the newsend amount X to address Y
start masternode with IP A.B.C.D and vin abcdabcdabcd using password QWERTY
