I am flabbergasted that this proposal isn't passing with unanimity. And so far I could not hear a single comment of a person presenting a good case why it should not be applied. Not even your reason,
@demo of the fact that this silence minorities. The only way not to silence minorities it to use a consent system (different from a consensus, btw) but this does not scale up to thousands of people participating. This is simply a problem that has not been solved by human civilization.
I first started thinking about using the median for nation wide referendums
in 2013. I think this is a great idea as in the eDemocracy often we end up only voting on boolean proposals. So much creativity gets lost. At least when the problem is unidimensional the solution is both what the majority wants, and within a certain range not fully determined by the person proposing. A truly community decision. Failing the idea of a tool for nations I started thinking that we should have started with a DAO. But now after seeing this sorry state of affairs I think Demo is optimist in proposing it for privx. And I start to think that governance must be set up rightly from the beginning, so it might only work on a new coin. Because policymakers generally cannot be trusted in taking decisions on policimaking. That is way too meta, and they always end up taking decisions that favours them. So I am now considering selling my masternode and starting a new coin specifically studied with mathematically fair governance in mind. And the rest will follow from it.
BTW, I am nudfelsyoshy in Dashcentral. This is what happens when you use random username without realising you will need those usernames to discuss stuff.
