@chaeplin @thelazier ^^^
HI Guys,
I am having a problem with the /p2pool-dash/data/dash/addr file. It was created when I set up my Pool, my pool is working and mining fine, it just doesn't come up on the list. Can someone help me with the file, I am not sure of the layout of the file.
Thanks
Gui
Pool Node Listing
A group of frequently asked question about the P2Pool Node Listing showing DASH nodes around the world.
How do I get my P2Pool Node added to your P2Pool Node Listing?
There is nothing, that you as a P2Pool Node operator must do, to get your node added to our node listing.
Getting your P2Pool Node listed happens automatically, provided that your node meets the following criteria;
Your Node must be up and running for at least 24 hours
Your node must be available to the public via a public IPv4 address
Your node must respond to a standard URL request (http://YourIPAddress:7903/fee)
Your nodes latency from Chicago, USA must be below ~5 Second response time
Our script reads your DASH address from the DASHD daemon address file.
Each day at 8:00 AM GMT-0500, our script executes, utilizing the list of known DASH addresses, processing a /fee request for nodes in the address file. If we get a response from your node, the node is GEO-coded and added to our listing. As long as your node is running and both In/Out node peers are able to connect to your node, then your nodes IP Address will appear in the DASHD address file.
If after 48 hours, your P2Pool node has still not appeared in our listing. Double check the requirements from the list above and ensure your node is configured appropriately.
Where are all those blocks? P2Pool seems to find only one today - just a bad luck?
