med4u
Now that 12.1 is out:no
u gotta wait for 12.1 release
Is it possible to setup a masternode on a Trezor?
Did you set it up on a remote server (like Vultr or something)? In reading through the Dashmnb protocol it seems like the Trezor needs to be connected to the machine that the masternode will run off (ie the server) am I misunderstanding that?I got my Trezor nodes running today with MNB script and A LOT of Chaeplins help. If you are technically minded that is the way to go as it works. Otherwise you can try using build 120 of Electrum-Dash, its pretty buggy (it wont register Trezor on windows 10 for example) but it should do the job as a couple of the electrum servers have already updated.
I hope that helps, hit me up if you want the 120 build.
Pablo.
So did you have the Trezor plugged into your local machine?
1) unlimited mn(s) with Acoount #x : Yes. each address should have 1K. no overlappingI've got questions1. can I run more than one MN on my trezor, and would I do that by simply putting them in the Masternode.conf file like usual?
Thanks for any help![]()
Yes.does the 1000 DASH stay on the trezor?
Not yet with dashmnb.trezor is out of stock at the moment. Is there support for doing the same thing but with the ledger nano s?
Thank you. Any idea of an ETA or who might know of an ETA?Not yet with dashmnb.
Electrum-dash will, I think.
The masternodeprivkey is not bound to your Dash in any way. You can use any dashd/dash-qt to generate a valid masternodeprivkey viaIm having some trouble getting my head around one thing: If your dash is on your trezor account, how do you get a masternode private key?
masternode genkey
