"Got updated entry" means that masternode with same vin is already online, at least that specific node thinks so. Should be "Got NEW Masternode entry" for a new one. Remove mncache.dat on your pi and see if it recognizes itself as a MN then. Also make sure that "masternodeprivkey" in pi's dash.conf matches the one for the alias.I have problem with my masternode on raspberry pi.
Dashd runs, it is fully synchronized.
command "dash-cli masternode debug" returns "Masternode successfully started"
When I call "masternode start-alias <my alias>" on my local mashine I see "Got updated entry for <my masternode ip>:9999" in debug.log on raspberry pi.
I dindn't see "Enabled! You may shut down the cold daemon".
Port 9999 is opened in firewall and forwarded on router.
I don't see my masternode in dashninja.pl.
I receiving status "ENABLED" when I calling "dash-cli masternode list full | grep <my masternode IP>" on my local computer.
Have anybody some ideas to resolve my problem?
My problem was resolved. Actually there was no problem with my masternode. I checked "masternodeprivkey" in pi's dash.conf. I removed mncache.dat and restarted dashd daemon. These actions did not make any results. But after approximately of 10 hours my masternode appeared in dashninja.pl without any action on my part. Thank you."Got updated entry" means that masternode with same vin is already online, at least that specific node thinks so. Should be "Got NEW Masternode entry" for a new one. Remove mncache.dat on your pi and see if it recognizes itself as a MN then. Also make sure that "masternodeprivkey" in pi's dash.conf matches the one for the alias.
Hello. I use this manual.
14. Lets fire it up for the first time
I can not run ./dashd getinfo
Error: There is no RPC client functionality in dashd anymore. Use the dash-cli u tility instead.
Hellp!
Hi there
I have tried make 12 version of dashd and got
"No working boost sleep implementation" with libboost version 1.49 and newwer
only with
./configure --with-boost=/usr/local/
addtional parameter I can made make
PS sorry for my pure english.
It told me the did wasnt in the directoryTo control dashd you use the dash-cli command. Dashd doesn't listen to commands directly anymore but listens to input from dash-cli.
So its:
. /dash-cli stop
arent you downloading the wrong Tar file? I think you are downloading the X64 version but you should download the ARM version for the PI.
X64 version shouldnt even be recognized by the system as an executable?
Try this one:
https://www.dash.org/binaries/dashcore-0.12.1.1-RPi2.tar.gz
I dont think this is Raspberry Pi related. Try this guide:
https://www.dash.org/forum/threads/taos-masternode-setup-guide-for-dummies-updated-for-12-1.2680/
And be sure to download the right file for the build! i still think you got the wrong one.
https://www.dash.org/binaries/dashcore-0.12.1.2-RPi2.tar.gz
good luck
Please make sure you have no special characters in rpc username/passwordwork fine
but
./venv/bin/py.test ./test
============================= test session starts ==============================
platform linux2 -- Python 2.7.9, pytest-3.0.1, py-1.4.31, pluggy-0.3.1
rootdir: /root/.dashcore/sentinel, inifile:
collected 20 items
test/integration/test_jsonrpc.py F
test/unit/test_dash_config.py .
test/unit/test_dashd_data_shims.py ..
test/unit/test_dashy_things.py .....
test/unit/test_models.py ..
test/unit/test_submit_command.py .
test/unit/models/test_proposals.py ...
test/unit/models/test_superblocks.py .....
=================================== FAILURES ===================================
__________________________________ test_dashd __________________________________
def test_dashd():
config_text = DashConfig.slurp_config_file(config.dash_conf)
network = 'mainnet'
is_testnet = False
genesis_hash = u'00000ffd590b1485b3caadc19b22e6379c733355108f107a430458c df3407ab6'
for line in config_text.split("\n"):
if line.startswith('testnet=1'):
network = 'testnet'
is_testnet = True
genesis_hash = u'00000bafbc94add76cb75e2ec92894837288a481e5c005f 6563d91623bf8bc2c'
creds = DashConfig.get_rpc_creds(config_text, network)
dashd = DashDaemon(**creds)
assert dashd.rpc_command is not None
> assert hasattr(dashd, 'rpc_connection')
E assert False
E + where False = hasattr(<dashd.DashDaemon instance at 0x762265f8>, 'rp c_connection')
test/integration/test_jsonrpc.py:30: AssertionError
===================== 1 failed, 19 passed in 2.59 seconds ======================
root@raspberrypi:~/.dashcore/sentinel#
and .....
File "bin/sentinel.py", line 244, in <module>
main()
File "bin/sentinel.py", line 149, in main
if not is_dashd_port_open(dashd):
File "bin/sentinel.py", line 136, in is_dashd_port_open
info = dashd.rpc_command('getinfo')
File "lib/dashd.py", line 42, in rpc_command
return self.rpc_connection.__getattr__(params[0])(*params[1:])
File "lib/dashd.py", line 31, in rpc_connection
return AuthServiceProxy("http://{0}:{1}@{2}:{3}".format(*self.creds))
File "/root/.dashcore/sentinel/venv/local/lib/python2.7/site-packages/bitcoinrpc/authproxy.py", line 86, in __init__
self.__url = urlparse.urlparse(service_url)
File "/usr/lib/python2.7/urlparse.py", line 143, in urlparse
tuple = urlsplit(url, scheme, allow_fragments)
File "/usr/lib/python2.7/urlparse.py", line 191, in urlsplit
raise ValueError("Invalid IPv6 URL")
ValueError: Invalid IPv6 URL
can u help me ???
Well, that's a known sentinel issue https://github.com/dashpay/sentinel/issues/4thx work!!!
i ve special chatacters in the previous version and it worked
