Liquidity Provider / Unlock for Mixing?
I've been running my wallet all day with 85 / 8 rounds but there's still no denomination. I guess there's no one else trying to mix their coins today?
moli, what do you mean?
- there is no splitting to 100s, 10s, 1s and 0.1s in coin control
- there is no "waiting in queue" status
- there is no newly anonymized funds
I guess the issue is the result of behavior I described in my pull request on github: most liquidity providers (and maybe some regular clients) are stuck on masternodes they received error from --> they can't switch and send new queue request --> not enough participants for those who still didn't get this error from MN.
Also DS not working properly because of this ^^^ so some might just turned it off.
To verify this I would like to ask everyone running liquidity providers for quite a long time to check an output of
cat debug.log | grep "CDarkSendPool::UpdateState()" | tail
Do you get 10 "CDarkSendPool::UpdateState() == 3 | 7"?
You probably already saw this in my log, but here's the most recent output:
2014-12-23 13:08:24 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:10:34 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:12:44 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:14:54 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:17:04 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:19:14 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:21:24 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:23:34 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:25:44 CDarkSendPool::UpdateState() == 3 | 7
2014-12-23 13:27:54 CDarkSendPool::UpdateState() == 3 | 7
yep, that's where I started from:wink: thanks for confirming it once again!
I'm running the wallet as a regular client, not as a liquid provider, just to see if could pair with any other reg. client or LP.
So far all I've got is a "Payment to yourself" and no "Darksend Denominate" fees at all, so there's no splitting to 100s, 10s, etc... The status has been "waiting in queue" and "Darksend is idle", and I get:
2014-12-23 16:37:23 CDarkSendPool::UpdateState() == 2 | 3
2014-12-23 16:37:23 CDarkSendPool::UpdateState() == 3 | 2
I am already mixed at round 9. The new client does not allow a higher setting. (So I can't mix with the regular client.)
I will try using LP now.
Sure, thanks. I have 85 DRK, 8 rounds. Let's see if it will work! :smile:
185 DRK, 99999 rounds (LP) liquidityprovider set to "1" (That means "much" mixing, right?)
The comment says "Darksend is idle". With the old client it used to change the phrase like... "attempting darksend mixing" periodically. This one has not changed from "Darksend is idle".
I have 8 connections to the network.
My wallet still hasn't got any Darksend Denominate but these in the debug.log:
2014-12-23 21:19:57 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:00 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:02 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:03 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:04 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:05 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:08 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:10 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:12 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:13 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:14 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:14 Submitted to masternode, waiting in queue ..
2014-12-23 21:20:15 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:16 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:17 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:18 Submitted to masternode, waiting in queue ...
2014-12-23 21:20:18 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:20 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:21 Submitted to masternode, waiting in queue .
2014-12-23 21:20:21 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:26 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:27 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:28 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:29 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:31 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:32 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:33 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:34 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:36 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:37 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:38 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:38 Submitted to masternode, waiting in queue ..
2014-12-23 21:20:39 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:41 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:42 Submitted to masternode, waiting in queue ...
2014-12-23 21:20:42 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:43 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:44 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:45 Submitted to masternode, waiting in queue .
2014-12-23 21:20:46 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:47 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:49 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:53 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:56 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:20:57 CActiveMasternode::ManageStatus() - Begin
2014-12-23 21:21:01 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:02 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:02 Submitted to masternode, waiting in queue ..
2014-12-23 21:21:03 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:04 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:05 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:06 Submitted to masternode, waiting in queue ...
2014-12-23 21:21:06 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:07 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:08 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:09 Submitted to masternode, waiting in queue .
2014-12-23 21:21:09 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:11 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:12 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:13 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:14 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:16 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:18 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:19 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:21 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:22 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:23 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:24 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:25 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:26 Submitted to masternode, waiting in queue ..
2014-12-23 21:21:27 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:28 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:30 Submitted to masternode, waiting in queue ...
2014-12-23 21:21:33 Submitted to masternode, waiting in queue .
2014-12-23 21:21:33 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:34 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:35 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:36 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:37 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:38 dseg - Sent 1 masternode entries to 107.170.94.162:9999
2014-12-23 21:21:39 dseg - Sent 1 masternode entries to 107.170.94.162:9999
