Ugh, I've been trying to redo my MN by using this tutorial, and I thought my problem was due to the disabling of logging in as root, but actually, it's because of the iptables. I can no longer ssh into my instance when I reboot after step 7. Does it mess with my ssh security group (ssh, port 22, my ip only)?
Is anyone else having trouble? Because I'm following these instructions to the T The only warning I got in the above steps was when I did:
update-rc.d ntp defaults
and it said system start/stop links already existed.
Why can't I log back in after reboot? (refused)
update-rc.d ntp enable
#/sbin/iptables-restore < /etc/sysconfig/iptables
*filter
:INPUT ACCEPT [1038:145425]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [434:87191]
-A INPUT -i eth0 -p tcp -m tcp --dport 9998 -j REJECT --reject-with tcp-reset
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 --tcp-flags FIN,SYN,RST,ACK SYN -m connlimit --connlimit-above 8 --connlimit-mask 24 --connlimit-saddr -j REJECT --reject-with tcp-reset
-A INPUT -i eth0 -p tcp -m tcp --dport 9999 --tcp-flags FIN,SYN,RST,ACK SYN -m connlimit --connlimit-above 2 --connlimit-mask 32 --connlimit-saddr -j REJECT --reject-with tcp-reset
-A INPUT -i eth0 -p tcp -m conntrack --ctstate NEW -m tcp --dport 9999 -j ACCEPT
-A INPUT -i eth0 -p tcp -j ACCEPT
-A OUTPUT -o eth0 -p tcp -m tcp --sport 9999 -m conntrack --ctstate NEW -j ACCEPT
-A OUTPUT -o eth0 -p tcp -m tcp --sport 9999 -j ACCEPT
-A OUTPUT -o eth0 -p tcp -m tcp --dport 9999 -j ACCEPT
-A OUTPUT -o eth0 -j ACCEPT
COMMIT
Ugh, would you believe I put the wrong ip address in the config file?![]()
First time, I forgot to even add my IP to the darkcoin.conf. lolUgh, would you believe I put the wrong ip address in the config file?![]()
ubuntu@ip-172-31-18-176:~$ darkcoind
terminate called after throwing an instance of 'std::runtime_error'
what(): locale::facet::_S_create_c_locale name not valid
Aborted (core dumped)
Stuck on # 11
can't seem to run darkcoind
Code:ubuntu@ip-172-31-18-176:~$ darkcoind terminate called after throwing an instance of 'std::runtime_error' what(): locale::facet::_S_create_c_locale name not valid Aborted (core dumped) ubuntu@ip-172-31-18-176:~$
:~$ export
declare -x HOME="/home/ubuntu"
declare -x LANG="en_US.UTF-8"
declare -x LESSCLOSE="/usr/bin/lesspipe %s %s"
declare -x LESSOPEN="| /usr/bin/lesspipe %s"
declare -x LOGNAME="ubuntu"
declare -x LS_COLORS="rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:*.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:"
declare -x MAIL="/var/mail/ubuntu"
declare -x OLDPWD
declare -x PATH="/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games"
declare -x PWD="/home/ubuntu"
declare -x SHELL="/bin/bash"
declare -x SHLVL="1"
declare -x TERM="xterm-256color"
declare -x USER="ubuntu"
:~$ locale
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_IDENTIFICATION="en_US.UTF-8"
LC_ALL=
Oh region...I had googled that, but want sure. Maybe because I chose Ireland as region? let me see...
Hmm, should not do so often(try connet to one ip address).chaeplin, I edited my previous post before you posted. Please look at the image I posted with the debug.log
12. using home pc, make 1000 DRK encryped wallet.dat to upload
* use home pc, not ec2
* install new wallet
* check account address 0 / getaccountaddress 0
* https://www.darkcointalk.org/thread...ternode-requirements-masternode-payments.225/
* send 1000 DRK to that address
* encypt wallet
* backup wallet
* using scp upload encypted backup wallet.dat to ec2 ubuntu home directory
ubuntu@ip-172-31-18-176:/usr/local/src/darkcoin$ rm peers.dat
rm: cannot remove 'peers.dat': No such file or directory
ubuntu@ip-172-31-18-176:/usr/local/src/darkcoin$ ls
COPYING INSTALL README.md bitcoin-qt.pro contrib doc share src
while I was waiting for help, I ran the command again and it works. Getting accepted messages. Guess I needed to let it connect before launching next command.
anyway, tried - darcoing getblockcount and its up to to height.
But, when running mining ufo, I get this - shouldn't testnet=true?
I also tried * check account address 0 / getaccountaddress 0
darkcoind gettaccountaddress 0
and it generated an address starting with "X" not with "m" like I see in the RC2 test net thread.
dammit, what am I doing wrong?
RC1
:~$ .darkcoin/darkcoind getinfo
"version" : 100400,
"protocolversion" : 70014,
"walletversion" : 60000,
"balance" : 1000.00000000,
"blocks" : 59329,
"timeoffset" : 0,
"connections" : 18,
"proxy" : "",
"difficulty" : 1424.99959688,
"testnet" : false,
"keypoololdest" : 1397159252,
"keypoolsize" : 101,
"paytxfee" : 0.00000000,
"mininput" : 0.00001000,
"unlocked_until" : 0,
"errors" : ""
RC2(testnet=1)
:~$ .darkcoin/darkcoind-testnet getinfo
"version" : 100500,
"balance" : 12395.30000000,
"blocks" : 1354,
"timeoffset" : 0,
"connections" : 8,
"proxy" : "",
"difficulty" : 0.20442253,
"testnet" : true,
"keypoololdest" : 1398603299,
"keypoolsize" : 97,
"errors" : ""
God dammit... so I decided to reboot, logged in, went to ./darkcoin and opened darkcoin.conf... empty!!
Did it 2x now, and it stays empty!! Dog dammit, took the day off for this and just sitting here...
So basically, since RC2 is out, this tutorial in no longer valid? (except obviously updated to RC2)
