How to gitian build dash under Debian Jessie using lxc
These are the deps that I have downloaded, which I believe is everything from that list, including the file that you mentioned.
gitian@dash:~/gitian-builder/inputs$ ls
10cc648683617cca8bcbeae507888099b41b530c.tar.gz  cdrkit-deterministic.patch                    protobuf-2.5.0.tar.bz2
bitcoin-deps-linux32-gitian-r9.zip               clang-llvm-3.2-x86-linux-ubuntu-12.04.tar.gz  qrencode-3.4.3.tar.bz2
bitcoin-deps-linux64-gitian-r9.zip               db-4.8.30.NC.tar.gz                           qt-everywhere-opensource-src-4.6.4.tar.gz
boost_1_55_0.tar.bz2                             dyld-195.5.tar.gz                             qt-everywhere-opensource-src-5.2.0.tar.gz
boost-linux32-1.55.0-gitian-r1.zip               ld64-127.2.tar.gz                             qt-linux32-4.6.4-gitian-r1.tar.gz
boost-linux64-1.55.0-gitian-r1.zip               libdmg-hfsplus-v0.1.tar.gz                    qt-linux64-4.6.4-gitian-r1.tar.gz
boost-mingw-gas-cross-compile-2013-03-03.patch   libpng-1.6.8.tar.gz                           zlib-1.2.8.tar.gz
cctools-809.tar.gz                               miniupnpc-1.9.20140701.tar.gz
cdrkit-1.1.11.tar.gz                             openssl-1.0.1k.tar.gz
Good, now
./bin/gbuild ../dash/contrib/gitian-descriptors/boost-win.yml
should work as intended.
