mranderson010
This is for the voters that do not use DASH CENTRAL and may miss the conversations there.......and also to get our proposal discussion back on track:
GuerraDiValute 1 point,3 hours ago
I will change my votes to yes and give this a chance. After reading what @oaxaca. has to say on forums, I do see this has potential even though it could be risky.
Reply
qwizzie 1 point ,6 minutes ago
Of all the budget proposals for the upcoming superblock, this one is most likely the most controversial one to vote on with clear risks at one side and possible huge benefits at the other side. I'm going to give myself a bit more time to think it through, but so far i'm leaning towards a no because i feel Dash budget system is currently still in an early phase where it profits more directly from smaller, well defined projects with a guaranteed outcome.
This kind of large project could fit Dash more once its has expanded its eco-system and has become a much larger force of power.
Reply
MrAnderson (proposal owner) 1 point ,less than 1 second ago
Thank your for the heart felt consideration and honesty. My only question is what if on March 31st/April 1st (last day to vote) we still have non-allocated DASH that will be DESTROYED, would you support us getting a chance to start proving out the "possible huge benefits?"
Right now with the majority of proposals that are >10% are there and that still leaves %44 (2,926.25) of the DASH budgeted for this payout out available and if not spent will never be created and lost forever. We are only asking for a little over 1/3 of those Dash left after all the less controversial supported proposals are already allocated.
Thank you again for your time and energy.
Reply
Darkcoins 2 points,15 hours ago
I think this could be huge for adoption and it's not so costy compared to what we're getting. This is a full cycle of people at every level in an industry using Dash! Combine that with the difficulty of getting banked in this industry. Think outside the box and realize what this actually means! Dash could be used to boost the whole industry past what fiat is currently limiting them with. And Dash would surge together with the industry. Big YES from me![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Reply
ageless 1 point,14 hours ago
I have voted yes. I think the Dash benefits in a lot of indirect ways by approving this. One mentioned in the text above is that a significant amount of Dash will be distributed within the multi-billion dollar industry. I also believe approving this proposal will encourage more proposals like this one to apply not to mention the potential positive PR this could generate for Dash. Aside from those indirect benefits the asymmetric risk associated with this proposal is very good. Dash should be seen as innovative and daring and I feel it would be a shame to pass up on this opportunity.
Reply
Roman 3 points,1 day ago
I am switching my vote to yes because even though I think this is still a super risky proposal if it works out the benefits for dash could be huge.
Reply
Reply
Reply
Reply
Reply
