Its ok, but must be a new empty address for 1k, if you dont like sending 1k at once, send it in smaller amounts to a different address in the same wallet and then group the coins together using 'enable coin control features' via settings/options and send 1k in one go to another address in wallet.OK thanks for the feedback!
So the TX still needs to be 1000 DASH? Would it be allright if the address that receives the TX already has some DASH?
I was also wondering, do you really have to specify addnode=23.23.186.131 in dash.conf?
Actually no, it doesn't care if this address already holds some funds or is it a brand new one - the only requirement is a tx with unspent 1000 DASH output.... but must be a new empty address for 1k....
Nice!
However this part
is redundant - any address can be masternode address now as long as it is funded via tx with 1000 DASH.
(we got rid of "getaccountaddress 0" a long time ago but it keeps resurrecting again and again in every guide)
"masternode outputs"?Can you post the 'command-line' script needed, within the QT console, that shows the transaction ID and the transaction number, the MN will need, to be inserted into the masternode.conf file correctly?
thx
