For those running several nodes, what's your approach for static IP addresses?
Damn, but still I haven't written my puppet script for nothing. I don't need that many changes to modify it to listen to several ip addresse instead of ports.
+1 wondering the same. i'm currently not having the time to test ipv6. could anyone just try out playing round with ipv6 subnets on a single machine? never seen any masternode using ipv6 yet....
I have found a log.
2014-07-09 08:38:47 send version message: version 70018, blocks=99062, us=my_server_ip:9999, them=113.106.61.49:58940, peer=175
2014-07-09 08:38:47 receive version message: /Satoshi:0.10.11.4/: version 70018, blocks=99062, us=my_server_ip:9999, them=[2001:0:9d38:6abd:14c9:2097:8e95:c2ce]:9999, peer=175
2014-07-09 08:38:47 send initial getblocks peer=175
2014-07-09 08:38:47 getblocks -1 to 0 limit 500 peer=175
2014-07-09 08:39:13 send last getblocks for 00000000000ad7e7375e95f977b9790a8ad6fe4bcd8a68e0290e0c9185e93872 peer=175
2014-07-09 08:39:14 getblocks -1 to 0 limit 500 peer=175
2014-07-09 08:39:26 received getdata for: block 000000000017310fbc383884b78ec805a0d75df55e304559e54944e4af301c8e peer=175
2014-07-09 08:40:40 getblocks -1 to 0 limit 500 peer=175
2014-07-09 08:41:23 send last getblocks for 0000000000107437c02d90800d0d09e0d8f46fa999907e26eadb2b5977d1ccd7 peer=175
2014-07-09 08:41:45 received getdata for: block 00000000000fe06f845f877b3e718b7184bfd77e17d1faa0269b0e9dd498fa69 peer=175
2014-07-09 08:41:47 received getdata for: tx ecae47930333d7d027efa0536d5bbed112b52fc0a1ff70c44ce4440c5139c99a peer=175
2014-07-09 08:42:21 received getdata for: block 00000000000c6619f48bfa3d74ba31bebd8bcccb20528f833ff5f185e555618e peer=175
2014-07-09 08:43:37 received getdata for: block 000000000013b693353eed6b09991033fdccc05c64d9b2eac312c504c738b40f peer=175
2014-07-09 08:45:03 received getdata for: block 000000000004d4da79f5b56ec5c5c51e5413adfe37062d0bae2ada830a3d0cb7 peer=175
2014-07-09 08:46:03 received getdata for: tx 258e4de28c59d608e1e3ce38620e7f52c7439e0a66ef0e81cf1e1ab6f156ce4a peer=175
2014-07-09 08:48:33 received getdata for: tx a7cf475b6242f353ab9a61c60f2ba42ee911b3797f7c3c5411054f34afd8713a peer=175
2014-07-09 09:02:09 getblocks -1 to 0 limit 500 peer=175
2014-07-09 09:04:28 send last getblocks for 00000000000122512d6ace24fb8bf57a12b3d98ac7dade91f3443a471d4ea9c6 peer=175
2014-07-09 09:04:28 getblocks -1 to 0 limit 500 peer=175
2014-07-09 09:04:34 received getdata for: tx 466fadcc649616dcae36489f059017459398a64f96d874bd4b09b83871eb17bc peer=175
2014-07-09 09:10:12 getblocks -1 to 0 limit 500 peer=175
2014-07-09 09:10:28 received getdata for: tx 883299e3491274131ca8b053175571300b8634056a2e7b8e3830a08d48cd0e44 peer=175
them=[2001:0:9d38:6abd:14c9:2097:8e95:c2ce]:9999, through ALG.
ALG is knid of NAT gateway between ipv4 and ipv6 network and has small number of ipv4 address.
Each ipv6 network has ALG to access ipv4 netwrok.
I heard ALG at 2002.
Edit
If ALG assign a ipv4 address and port 9999 to Masternode in ipv6, should work.
As ipv4 clinet will use '113.106.61.49:9999' to connect, not [2001:0:9d38:6abd:14c9:2097:8e95:c2ce]:9999.
