Electrum Dark
That could be it.
Though, looking at Poolers source code for the old version the only time he messed with the POW was for the actual electrum-client and not the server. With litecoin using scrypt instead of sha256 I'd assume if it was needed it would need to be edited in both the server and client.
https://github.com/pooler/electrum-ltc-server/compare/spesmilo:master...master
I'll spend some more time on it.
Hmm.. strange if it works at all... that's what my logic was based on - for example:
This https://github.com/Propulsions/electrum-drk-server/blob/master/src/blockchain_processor.py#L655 uses hash_header I mentioned before and stores last_hash
and then https://github.com/Propulsions/electrum-drk-server/blob/master/src/blockchain_processor.py#L662 uses that last_hash to call "darkcoind getblock <last_hash>"
The last statement will definitely fail if hash_header used sha256d to form last_hash earlier.
Alright. I've imported the hash function from p2pool. I'm able to start and stop the server with no issues. Once again, I'm rebuilding the full blockchain_headers file from scratch.
The only thing that looks concerning is the coin count:
Bash:
$ ./run_electrum_server
INFO:drkelectrum:Starting Electrum Darkcoin Server on localhost
INFO:drkelectrum:Database version 3
INFO:drkelectrum:Blockchain height 12051
INFO:drkelectrum:UTXO tree root hash: 685ea9fae9c6a4a38efb921b9b405e76280c30fa7c9765d8c7be84a03ca625af
INFO:drkelectrum:Coins in database: 806940910993317
INFO:drkelectrum:catching up missing headers: 12018 12051
INFO:drkelectrum:TCP server started on 127.0.0.1:50011
INFO:drkelectrum:SSL server started on 127.0.0.1:50012
INFO:drkelectrum:catch_up: block 13000 (4.787s 28.705s) d44b4565ad30dd24bf8a822bbed5226c1bdaff61bce12ba9fc32b16a800b5e92
^CINFO:drkelectrum:Stopping Stratum
INFO:drkelectrum:closing database
INFO:drkelectrum:Blockchain is up to date.
INFO:drkelectrum:utxo not in database; postponing mempool update
INFO:drkelectrum:Memory pool initialized.
INFO:drkelectrum:Closing database...
INFO:drkelectrum:Database is closed
INFO:drkelectrum:Electrum Darkcoin Server stopped
Looking above it shows a block height of 12051 with a coins in database of 806 940 910 993 317.(806 trillion) That can't be right it should be 2,924,324.0 DRK
Although, looking at a post on BCT on Electrum,
Block height is 296956 while Coins in database shows 1 267 617 386 701 994 which is absolutely wrong.(over one quadrillion)
Bash:
[21/04/2014-12:37:56] Database version 3
[21/04/2014-12:37:56] Blockchain height 296956
[21/04/2014-12:37:56] UTXO tree root hash: 469a5e3385265bc67a0f9479cc26f012d31b6544728148faf594140411d964d3
[21/04/2014-12:37:56] Coins in database: 1267617386701994
[21/04/2014-12:37:56] catching up missing headers: 296934 296956
[21/04/2014-13:24:55] catch_up: block 297000 (4.029s 2814.156s) 36ce5c0b18d7b84140e4b87c8d0334046c267c024d1ef51fe34b43573a97d54f
[21/04/2014-14:04:53] Blockchain is up to date.
[21/04/2014-14:05:40] utxo not in database; postponing mempool update
[21/04/2014-14:05:40] Memory pool initialized.
[21/04/2014-14:05:40] TCP server started on port 50001
[21/04/2014-14:05:40] SSL server started on port 50002
[21/04/2014-14:05:40] Stopping Stratum
I'm going to go ahead and create the database. I'm not 100% sure it's a good hash function though at this time.
well now you got darkcoin hash, but you also need darkcoin subsidy i guess, this calculates the block value and thus the total coins.
I found the problem with the wrong coinbase reporting on the server. I have a working version, but still want to finish building all the UTXOs before declaring victory - 8 hours more to go...
Will do a pull request to Propulsion's Github account when satisfied.
Working on the client in the meantime. Should be simple.
Finally got the UTXO to build... Got less than 3 DRK difference on coinbase (over 5M DRK) between the UTXO and Chainz block explorer.. interesting... It used to be a perfect match until half way down the blockchain...
Still working on the client... managed to get a transaction to show up in my wallet
More info tomorrow...
It is a known fact that Electrum servers are not rewarded with their work (BTC - LTC - ..._). Sadly...
If Darkcoin wants to have Electrum-drk servers to support the (SPV) Electrum feature - someone will have to support them.
If an Electrum-DRK solution can be found, Darkcoin will have to fund a minimum of 3 servers. Can Darkcoin do that?
To run an Electrum-DRK server would require at least 8GB Ram and 40GB HD - do the math with cloud servers... times 3...
Yeah that should be no prob. I can contribute at least one of such machines.
Me too, at least two heavy duty machines available. eduffield will bring in another machine for sure which i can manage.
Ok, we need to get some overview, this is what github has to offer currently:
??? who is running this one?
https://github.com/electrum-drk/electrum-drk
https://github.com/electrum-drk/electrum-drk-server
This is me, also owning the domain electrum-drk.org
