Same.I will start one under drk.khavr.com as soon as I'll get some time.
Really do need a picture to see. Also please use the forum feedback forum.Propulsion, on my screen I can't see akhavr's post because most of it is covered by a sticky google ad.
EDIT: Now that ad was removed. Thanks!![]()
Added two servers.
https://github.com/mazaclub/encompass/pull/24/files
"not yet" - ELM4ever said it needs more testing. but if it does we should stick to encompass, as it seems actively maintained.So we are using Encompass as the client and which repository as the electrum-drk-server itself?
Also, I was under the impression Encompass didn't support Trezor.
volunteers wanted!!!So we are using Encompass as the client and which repository as the electrum-drk-server itself?
FQDN is always better, but not mandatory.
However, it is mandatory that people running a server to use IRC in their server config file (irc = yes), and that they also define the report_host variable to match their FQDN or external IP address. Otherwise, your server will not get listed in the clients. "103.13.228.168" is currently is this situation, he (she) is running a server, it is up, but it is not listed in the encompass clients because not in IRC.
My server currently running is based on yours.Which repository are we going to use for the server? The one under my github account or another?
I'll knock this out right now.
Propulsion : Hello D_dct! You went for 1000 pruning with FQDN electrum.darkcointalk.org? You wimp! Why not go all the way to 10k? There is only 1MB difference in the UTXOs!Making a FQDN for a MN and setting it up right now.
electrum.darkcointalk.orgHello D_dct!
I was able to connect to your server - it works well! Both TCP and SSLelectrum.darkcointalk.org
(haven't opened any ports specifically for Electrum yet though)
I guess next would be to test the client?
That's the one! Congratulations! You are an official Electrum-DRK server! And you show up in the client list of available servers.ELM4ever
[04/03/2015-02:46:57] sent tx: 5a233ed0f7063f25836cbdc349e58287f65e4d34b10ddee9$
[04/03/2015-02:46:59] cache: invalidating Xppn8RSZ4ffYMXu1rL5EZucBaHNDeis2u3
[04/03/2015-02:46:59] cache: invalidating XouAQGK2GGeiSE6Xa2sgPhmTRsPLyxZAyw
[04/03/2015-02:47:19] blockchain: 229644 (0.229s)
[04/03/2015-02:47:29] cache: invalidating XouAQGK2GGeiSE6Xa2sgPhmTRsPLyxZAyw
[04/03/2015-02:47:29] cache: invalidating Xppn8RSZ4ffYMXu1rL5EZucBaHNDeis2u3
[04/03/2015-02:47:29] blockchain: 229645 (0.071s)
It's all there; looks good.
Now the next step is for you to upgrade to 10k pruning... instead of 1k.
Also try Encompass 0.4.4 for your client.
[04/03/2015-08:36:14] Starting Electrum-DRK server on localhost
[04/03/2015-08:36:16] Database version 3
[04/03/2015-08:36:16] Blockchain height 209517
[04/03/2015-08:36:16] UTXO tree root hash: 6b96a0cb2565e13d82a28ae56411bad910a1d2922d40e068f7c3e5d7fd346176
[04/03/2015-08:36:16] Coins in database: 507314432375985
[04/03/2015-08:36:16] catching up missing headers: 209510 209517
[04/03/2015-08:36:16] TCP server started on 127.0.0.1:50001
[04/03/2015-08:36:16] SSL server started on 127.0.0.1:50002
[04/03/2015-08:36:16] HTTP server started.
[04/03/2015-08:36:16] HTTPS server started.
[04/03/2015-08:36:16] Stopping Stratum
[04/03/2015-08:36:16] Error: make sure you run darkcoind with txindex=1; use -reindex if needed.
[04/03/2015-08:36:16] blockchain reorg 209517 00000000000ac9c11b397217f305237975a0a8b68a8b2b7373b2b2ed6ef4f208 000000000001d1a5a8bac1691b7b5c442dabf3bc18f83363f42ab4a212618024
[04/03/2015-08:36:16] no undo info for 209517
[04/03/2015-08:36:17] Closing database...
[04/03/2015-08:36:17] Database is closed
[04/03/2015-08:36:17] Electrum-DRK Server stopped
