DashTV - The easy way to keep an eye on your investment
Hey @pille
are your stats relying on this ?
they seem a bit off
Hey @pille
they seem a bit off
Yeah, i noticed a difference in annual revenue between Dashtv (6,65%) and Crowning's site : http://178.254.23.111/~pub/Dash/Dash_Info.html --> ROI (7,07%) at first.
Then i remembered that DashTV used to show 8% with annual revenue, so the 6,65% seems .. off,
Edit : stats.masternode.me has it currently on 8.24%/8.08% masternode annual return, which seems more correct.
yep, I need a new reliable data source, moocowmoo's is not anymore :( maybe we can get a official source on dash.org one day, that would be great.
i pinged the team onto this ;)
@tungfa we are back (moo's stats are working again) ;)
Pille, if you are still using https://explorer.dash.org please be informed that there is now a redirect going on that specific block explorer towards https://explorer.dash.org/insight/
You may need to update your site towards using that insight block explorer.
Your site currently can't seem to fetch specific Dash addresses to calculate a correct balance, price is still showing a correct value though.
[QUOTE = "MangledBlue, post: 77026, member: 1612"] Если вы могли бы уменьшить это примерно на 25% или около того - это будет соответствовать моему экрану
немного больше
спасибо заранее :)
кроме этого - отличная работа :-D [/ QUOTE]
Cool service
@pille Hey man, in recent months I have not had any luck with the address balance lookup feature. Has this been depreciated?
Or maybe I have messed something up with the url... not sure.
Thanks for your feedback! Just checked and you are right, the error is on my end. Can't reach the blockexplorer like I did in the past. Does anybody know an alternative URL I can use. It needs to accept a Dash public address within the URL and respond with the balance.
Edit: @JGCMiner fixed, should be working again as usual, please try it out.
@pille It’s working now. Thanks for the fix!
