v12.2 Testing
Hello everyone,
Looks like we finally had a successful migration on testnet and solved all known (critical) issues, so we are ready to start the final phase which is a public testing.
This release includes:
- DIP0001 implementation https://github.com/dashpay/dips/blob/master/dip-0001.md
- 10x transaction fee reduction (including InstantSend fee)
- InstantSend vulnerability fix
- Lots of other bug fixes and performance improvements
- Experimental BIP39/BIP44 complaint HD wallet (disabled by default, should be fully functional but there is no GUI yet)
Detailed release notes: https://github.com/dashpay/dash/pull/1675 (work in progress)
Before testing:
- Make sure you made a backup of you mainnet datadir somewhere or at least a backup of wallet.dat/dash.conf/masternode.conf;
- Remove testnet3 folder, old testnet is not compatible anymore, you need to sync from scratch.
What/how to test:
- DIP0001 is already active on testnet, so it's capable of handling 2Mb blocks now and have lower fees. Send some transactions but please spam responsibly :)
- InstantSend fix is also activated, so InstantSend is enabled on testnet, give it a try;
- Try mixing too, let's see how it works now;
- Run a masternode or two, make sure it is paid;
- Create some proposals and/or up/down-vote some of them (remember, you need a masternode to vote but you don't need a masternode to submit a proposal).
What else you can do:
- Report serious issues (crashes/hangs/GUI glitches) : https://github.com/dashpay/dash/issues/new
- Participate in translations : https://www.dash.org/forum/threads/12-2-translations.17122/
All users:
Latest binaries:
- Windows : https://bamboo.dash.org/browse/DASHW-DEV/latestSuccessful/artifact/JOB1/gitian-win-dash-dist/
- MAC : https://bamboo.dash.org/browse/DASHM-DEV/latestSuccessful/artifact/JOB1/gitian-osx-dash-dist/
- Linux : https://bamboo.dash.org/browse/DASHL-DEV/latestSuccessful/artifact/JOB1/gitian-linux-dash-dist/
- Raspberry Pi : https://bamboo.dash.org/browse/DASHP-DEV/latestSuccessful/artifact/JOB1/gitian-RPi2-dash-dist/
Testnet tools (explorers, faucets, pools) : https://www.dash.org/forum/threads/testnet-tools-resources.1768/
MNOs:
Wiki: https://dashpay.atlassian.net/wiki/spaces/DOC/pages/118162190/Masternodes+under+testnet
Sentinel : https://github.com/dashpay/sentinel/tree/core-v0.12.2.x
NOTE: Make sure you pulled Sentinel from `core-v0.12.2.x` branch and changed network to `testnet` in `sentinel.conf`. If you already have a mainnet masternode on the same server, do NOT run testnet masternode in the same datadir as your mainnet masternode (i.e. `.dashcore`). Create new folder specifically for testing (e.g. `.dashcore_test`) and make sure you use `-datadir=<yourtestnetdatadirhere>` cmd-line parameter for dashd and dash-cli. You'll also need a separate crontab line for testnet Sentinel. If you are not 100% sure what you are doing, I'd recommend setting up a new machine/instance for testing purposes only instead of reusing your mainnet server.
@UdjinM6
Win 7 x64 - v0.12.2.0-4ecbedb
Menu -> Help -> Command-line Options ->
-assumevalid=<hex>
If this block is in the chain assume that it and its ancestors are valid and potentially skip their script verification (0 to verify all, default: 00000000000000b4181bbbdddbae464ce11fede5d0292fb63fdede1e7c8ab21c, testnet: 00000ce22113f3eb8636e225d6a1691e132fdd587aed993e1bc9b07a0235eea4)
Are those defaults right?
It's same in the translated and original english lang.
@UdjinM6
-assumevalid=<hex>
Yes
https://github.com/dashpay/dash/blob/v0.12.2.x/src/chainparams.cpp#L121
https://explorer.dash.org/block/00000000000000b4181bbbdddbae464ce11fede5d0292fb63fdede1e7c8ab21c
https://github.com/dashpay/dash/blob/v0.12.2.x/src/chainparams.cpp#L260
https://test.explorer.dash.org/bloc...6e225d6a1691e132fdd587aed993e1bc9b07a0235eea4
Is anything wrong with them?
Welp, my wallet doesn't seem to create a .dashcore folder and doesn't give an error, when I do dash-cli getinfo I get the normal output only everything stays at zero except that it shows 8 connections to the network. Ubuntu 16 running dash in the bin folder. I'll try pulling out the old instructions to see if I forgot something. But in case it happens to others, this is more verification?? I used the binaries, didn't compile.
Edit: It just took time, this morning they showed up. Not sure why so much time?
Notes are for my stupid head: Forgot dash.conf and was syncing with main network, and probably wasn't happy about it :p
excellent news :) i will hopefully get my azure VMs running today, been a while since i used them for testing :)
I did some mixing earlier (7 october 2017) with 6 wallets and 1 of these 6 wallets is having consistently difficulty syncing correctly as of today.
Note : all my wallets were downloaded and synced from scratch, right after the second fork of Testnet which took place earlier (4th of october 2017)
During startup of this specific wallet (Dash Core version v0.12.2.0-4ecbedb), it shows 11 days behind (latest block : 5279)
In the splitscreen it goes to :
Synchronizing masternodes
Synchronizing masternode payments
Synchronizing governance objects
It then completes the synchronization
Splitscreen shows :
Progress increase per hour : calculating
Estimated time left until synced : calculating
Number of active connections : 8
When i hide the splitscreen : wallet provide no warning that it is still out of sync (it is in fact still stuck on block 5279).
All my mixing transactions from 7 october are all still unconfirmed
I included the debug.log in text format.
I can of course just delete the whole blockchain of that wallet and have it synced from scratch, but i find it strange that this specific
wallet behaves this way (it gets stuck in the blockchain sync, but is allowed to continue with the masternode synchronization like nothing happened and afterwards
does not show its behind in the blockchain sync).
The other 5 wallets had no difficulty syncing whatsoever and are currently busy with mixing (which is going nicely).
Edit : there was something strange about that wallet when i was trying to mix on 7 october 2017 anyways, as i got hit with a lot of Privatesend collateral payments :
Link : https://imgur.com/sGAVyvb
I will include a larger debug.log in a rar file (just rename debuglarge.log.rar.txt to debuglarge.log.rar)
  • debug.log.txt
  • debuglarge.log.rar.txt
v0.12.2.0-4ecbedb
Windows 10, 64bit
I'm noticing quite a few "Privatesend request incomplete, collateral not valid. Will retry" messages during mixing, is this normal ? Its always with submitted denom : N/A
It could be slowing the mixing down a little bit..
Edit 1 : this Privatesend message seems to appear irregular, not as often as i first thought.
Edit 2 : this message seems to be created when we receive a Privatesend Collateral Payment and keeps being shown untill that Privatesend Collateral Payment transaction gets confirmed through POW.
Dash wallet will actually stop further mixing untill that Privatesend Collateral Payment transaction gets confirmed, is it really necessary to wait on that POW confirmation of these Privatesend Collateral Payments and thereby putting the mixing on hold ?
Reusing my testnet 0.12.1.5 folder caused the 0.12.2 version to be stuck at -12days (which does not make much sense as I was up to date yesterday). Deleting the testnet folder and/or using a new one worked right away (synced in less than a minute). I guess you have been using the testnet 0.12.2 internally before and now there is a testnet chainsplit somewhere in the past (as opposed to only today).
Yeah, you are correct. I was using testnet 0.12.2 internally before and i also think a chainsplit is the most likely problem. I'm just mentioning the problem in case it could somehow effect our upgrade on Mainnet as this problem
occurred a few days after they forked testnet v0.12.2 for the second time (planned fork).
Question : How can we test the HD key generation, which is currently disabled ? Is it scheduled for v0.12.2 or for a later version ?
Edit : never mind --> Experimental BIP39/BIP44 complaint HD wallet (disabled by default, should be fully functional but there is no GUI yet)
ok, thanks. I also noticed that some of my existing transactions from testnet 0.12.1.5 are now showing "Status: Open for 222316 more blocks" and showing in my wallet transaction list, but basically are not included in my balance. All new transactions from today work fine so far, maybe I should have read in detail the above instructions to delete the testnet3 folder and start with a fresh folder :)
ok, thanks. I also noticed that some of my existing transactions from testnet 0.12.1.5 are now showing "Status: Open for 222316 more blocks" and showing in my wallet transaction list, but basically are not included in my balance. All new transactions from today work fine so far, maybe just tell users when using the testnet to always start with a fresh folder for it.
Because testnet was forked (twice) they did ask us to delete the whole folder :
I already did that because i was testing v0.12.2 ahead of time (after the second fork).
Basicly when Testnet forks its better to have a new wallet created, so you get rid of the transactions that are no longer valid on current chain.
I'm gonna test InstantSend next, if anyone wants to test Instantsend i have some wallet addresses people can test it on :
yLzK59WHCfJ4uwNnx5ArWcin4xcwrYsckZ
yPyJ33py3SNPRsECRF7XpFubwT91pq1aVR
yQ8FS398GChJXZsK3bjw534BUWuXZsohwc
yj2h6wr5zDgZXG1Aa2KeSxcaeWTmWJJhL2
yiMyzqrRTYZcDDHi4a35TrpmzRLxeDqqRu
So far InstantSend seems to work fine (i did 3 InstantSend transactions which instantly got confirmed 5 times).
Have send you some
https://test.explorer.dash.org/tx/607f8e36fad5190544a13a256b9285ba56388f708f94833fd9a0f4ccc0f82040
BTW: wouldn't it be nice if the transaction window would show a link to the dash explorer website? MyEtherWallet or Ledger/Tresor interfaces have such links and they are very useful for newbies and a time safer for everyone else.
I believe under wallet preferences on the Display tab you can populate the field "Third party transaction URLs" and if you did something like "http://test.insight.masternode.io:3001/tx/%s" then on the transaction tab when you right click a transaction it will display a clickable link to said transaction. I guess we don't populate those fields by default as we don't have a cluster of reliable insight nodes to serve this data to the entire network of wallet users.
yeah that would be great, if the functionality is already there and just needs to be filled in, it should be able to add it for 0.12.2?
Mixing in 3 wallets, +50% done
800 coins @ 8 rounds
Time since the beginning: 5h
I'm trying to send 1 tDASH via IS but receive error :
"InstantSend doesn't support sending values that high yet. Transactions are currently limited to 1000DASH."
Linux wallet, ubuntu 16 OS
EDIT: Restarted the wallet and it worked. IS working good. I don't know what was the problem
@UdjinM6
Test report - Win 7 x64 - v0.12.2.0-4ecbedb
Note: blocktime was in this test about (PITA slow) 6-10 mins.
Mixing test:
2 wallets, 200 tDASH, 2 rounds,
both wallets completed mixing in 40 minutes,
final balance was 230 tDASH in each wallet.
Normal send test:
Works ok.
IS send test:
Works ok.
PS send test:
Did not find enough funds,
amount 12 tDASH, PS balance 81 tDASH.
PS + IS test:
