Tried encompass - not happy
turbobc
Hi,
Tried out encompass as I would like to use a dash-electrum.
Send some dash to it - it got there fine and eventully noted the confirmed transaction.
Tried sending from it, but it does not work (windows 8). After entering correct password
the "Signing" message comes up, goes away and nothing happens (wallet is connected and in sync).
Sooo.....lets export private keys and import them into dash wallet me thinks.
But dash not happy with the format of the private key from encompass. How do I reformat ?
(the private keys from encompass all have a 5 as the first character).
Any help would be much appreciated.
I'm sure someone here will help you, but just so you know, a standalone Dash-Electrum wallet is almost finished and will be released soon...
But that doesn't help you now, hopefully someone with some expertise sees this bump! :smile:
Hi,
Please report the issues to their github site:
https://github.com/mazaclub/encompass/issues/
You can also speak with the developers on Freenode IRC by joining their channel #mazaclub
(/join #mazaclub on your IRC client or use webchat https://webchat.freenode.net/ )
Any idea when can we expect to try electrum?
