Problems after upgrading to 12.2
Pietro Speroni
Active member
From when I upgraded to 12.2 I keep having problems with the masternodes.
They keep not working. One is refusing to even start syncing. After 12 hours it still says:
"AssetID": 0,
"AssetName": "MASTERNODE_SYNC_INITIAL",
"AssetStartTime": 1510777732,
"Attempt": 0,
"IsBlockchainSynced": false,
"IsMasternodeListSynced": false,
"IsWinnersListSynced": false,
"IsSynced": false,
"IsFailed": false
this one is on an Ubuntu 17.10 x64 with 1024 MB and 25 GB SSD.
On the other side the one on CentOS 7 x64 with 1024 MB and 25 GB SSD.
seem to start ok and now is:
"AssetID": 999,
"AssetStartTime": 1510682349,
"Attempt": 0,
"IsBlockchainSynced": true,
"IsMasternodeListSynced": true,
"IsWinnersListSynced": true,
"IsSynced": true,
"IsFailed": false
But on dashcentral it says:
Error: Your masternode dropped off the masternode list and is not enabled!
and IP not available
I did everything that was told to do for the upgrade in the instructions. Is there anything I needed to do.
Thanks.
Dont trust dashcentral.
Look directly at the place where dashcentral gets its info, which is https://www.dashninja.pl/
so on dashcentral it says that the first one has the port open (but it is still not syncing and thus not working)
while the second is now working (but it has the port closed). If this did anything it added to the confusion o_O
So the first question would be, why is the first masternode not syncing?
Once that is handled I will see if the other is fixed or not
You need to start from a solid base before we start looking at problems with your configuration. Your spec is currently probably too low, you may be running out of memory while while processing network votes. You should currently be aiming for around 2GB RAM + 4GB swap.
Use "dash-cli getinfo" and check if you node is on the same block as https://explorer.dash.org or https://chainz.cryptoid.info/dash/
If it's not, find the next block (block in getinfo output + 1) in either one of explorers, grab its hash and use these commands:
dash-cli mnsync reset
dash-cli reconsiderblock <blockhashhere>
dash-cli clearbanned
(<blockhashhere> - block hash from block explorer, without < >)
Then start it from your local 12.2 wallet again.
If you run masternode as a qt wallet you are doing it wrong, don't do this :)
For local wallet (the one you start your remote masternode from) - yes, ignore the dash-cli part
Thank you very much.
I investigated a bit more,
First of all, I do have dash-cli!!!
It's just that to call it I need to call ./dash-cli and not just dash-cli.
Some things are so natural for some people that they forget to tell them :)
So I run the dash-cli and here is what I got:
"version": 120201,
"protocolversion": 70208,
"walletversion": 61000,
"balance": 0.00000000,
"privatesend_balance": 0.00000000,
"blocks": 769068,
"timeoffset": 0,
"connections": 8,
"proxy": "",
"difficulty": 35181684.73744042,
"testnet": false,
"keypoololdest": 1508498810,
"keypoolsize": 1001,
"paytxfee": 0.00000000,
"relayfee": 0.00010000,
"errors": ""
Now the block where it is blocked is 769068. So I should look for the hash of 769069
Which I think is here:
https://explorer.dash.org/block/000000000000006886127fe2947b433336715331e4afec2abbe039099b5e2cb1
The hash then is this:
I don't have a gui :).
Then:
~/.dashcore$ ./dash-cli mnsync reset
success
But then when I do:
:~/.dashcore$ ./dash-cli reconsiderblock 000000000000006886127fe2947b433336715331e4afec2abbe039099b5e2cb1
I get:
error code: -5
error message:
Block not found
I also tried to add the next on one, but I got the same error.
Still blocked.
Still blocked.
What about the previous block 769067? Or the same 769068? Have you tried to reconsider them?
As long as you are stuck in 769068, the system correctly reports "Block not found" because you are trying to REconsider the non existent (for your system) block 769069. Obviously you cannot REconsider block 769069. You have to consider it first, before REconsidering it!!!!
So maybe you should try to reconsider block 769068, but dont do it unless @UdjinM6 says so.
"version": 120201,
"blocks": 769068,
"timeoffset": 0,
"connections": 8,
"proxy": "",
"testnet": false,
"errors": ""
Then:
success
But then when I do:
I get:
error code: -5
error message:
Block not found
Still blocked.
Hmmm... interesting.
What is the output of
./dash-cli getchaintips 3
Or maybe you have no blocks because you have no good peers around you? Pick some masternode from the list, grab its IP and use it
./dash-cli addnode <IPhere>:9999 onetry
If this is the case, maybe you should propose a DIP.
  1. The masternode who thinks he has bad peers, reports that.
  2. The rest masernodes check these supposed bad peers.
  3. If the majority also agree that they are bad peers, then these bad peers are automatically banned.
  4. If the majority founds that the peers are not bad, then they ban the one who reported them.
  5. The ban remains valid until the bad becomes good, and upon bad's request to 3 random good masternodes who are willing to confirm that badness is gone.
  6. The service of confirming the status change of a banned could require some fee paid by the banned, so that the good will have incentives to provide this service and to accept requests from the banned.
If they found that the peers are not bad, then they ban the one who reported them.
The ban remains valid until the bad becomes good, and upon bad's request to at least 3 random good masternodes to confirm that.
It could be that the whole cluster is isolated due to a fork, so banning more neighbors won't help, you won't discover new peers and will have to pick them manually anyway.
If the cluster is tottaly isolated due to a fork , then the peers from this cluster do not report bad blocks. They report good blocks which are forked blocks.
The issue resolved by the above proposed DIP is when some mnos report bad blocks (blocks that have corrupted signatures).
Bitcoin (and Dash) always assumes that the majority is good, there is not any dishonest majority protocol implemented yet.
They only report good block if there is a miner. If this cluster consists of a non-mining nodes on a wrong chain and all miners switched to other peers and are mining on the right chain, then the whole cluster will just sit there waiting for blocks forever (well, for 24h actually, until the ban goes away).
In that case you should not call it "wrong chain".
You should call it "frozen chain", as long as the last block of the banned cluster is not wrong, is it?
For the "frozen chain" problem an improved DIP should be proposed, that takes into account the existence of a miner in the cluster.
So, getinfo now gives:
"version": 120201,
"blocks": 769068,
"timeoffset": 0,
"connections": 23,
"proxy": "",
"testnet": false,
"errors": ""
While getchaintips gives:
"height": 769079,
"hash": "000000000000008754811f3bbaacd16d0b3afef07b6a498626bab80fa7027155",
"difficulty": 15215184.12686991,
"chainwork": "0000000000000000000000000000000000000000000000598465deb4ec8673b1",
"branchlen": 11,
"status": "headers-only"
"height": 769068,
"hash": "00000000000000233e44da14628ac182b13df1774b709cb07ea2233444d92e40",
"chainwork": "000000000000000000000000000000000000000000000059756f5105d3d81a23",
"branchlen": 0,
"status": "active"
"height": 769066,
"hash": "00000000000000219eb0ff02c8ac196eeaceee1ce7453d228a1af77e129b607f",
"difficulty": 38353722.43502148,
"chainwork": "00000000000000000000000000000000000000000000005971283f0510761f8a",
"branchlen": 1,
"status": "invalid"
did I went off into a sidebranch?
