yamada
I get the following error and never had it before.
Somebody has an Idea?
root@nognog19:/home/Downloads/darkcoin# time make -f makefile.unix
make: makefile.unix: No such file or directory
make: *** No rule to make target `makefile.unix'. Stop.
real 0m0.002s
user 0m0.001s
sys 0m0.001s
root@nognog19:/home/Downloads/darkcoin# qmake
Project MESSAGE: Building with UPNP support
Removed plural forms as the target language has less forms.
If this sounds wrong, possibly the target language is not set or recognized.
root@nognog19:/home/Downloads/darkcoin# make
cd /home/Downloads/darkcoin/src/leveldb && CC=gcc CXX=g++ make OPT="-m64 -pipe -fstack-protector-all -D_FORTIFY_SOURCE=2 -O2" libleveldb.a libmemenv.a
make[1]: Entering directory `/home/Downloads/darkcoin/src/leveldb'
make[1]: `libleveldb.a' is up to date.
make[1]: `libmemenv.a' is up to date.
make[1]: Leaving directory `/home/Downloads/darkcoin/src/leveldb'
cd /home/Downloads/darkcoin; /bin/sh share/genbuild.sh /home/Downloads/darkcoin/build/build.h
/usr/bin/uic-qt4 src/qt/forms/sendcoinsdialog.ui -o build/ui_sendcoinsdialog.h
/usr/bin/uic-qt4 src/qt/forms/coincontroldialog.ui -o build/ui_coincontroldialog.h
/usr/bin/uic-qt4 src/qt/forms/addressbookpage.ui -o build/ui_addressbookpage.h
/usr/bin/uic-qt4 src/qt/forms/signverifymessagedialog.ui -o build/ui_signverifymessagedialog.h
/usr/bin/uic-qt4 src/qt/forms/aboutdialog.ui -o build/ui_aboutdialog.h
/usr/bin/uic-qt4 src/qt/forms/editaddressdialog.ui -o build/ui_editaddressdialog.h
/usr/bin/uic-qt4 src/qt/forms/transactiondescdialog.ui -o build/ui_transactiondescdialog.h
/usr/bin/uic-qt4 src/qt/forms/overviewpage.ui -o build/ui_overviewpage.h
/usr/bin/uic-qt4 src/qt/forms/sendcoinsentry.ui -o build/ui_sendcoinsentry.h
/usr/bin/uic-qt4 src/qt/forms/askpassphrasedialog.ui -o build/ui_askpassphrasedialog.h
/usr/bin/uic-qt4 src/qt/forms/rpcconsole.ui -o build/ui_rpcconsole.h
/usr/bin/uic-qt4 src/qt/forms/optionsdialog.ui -o build/ui_optionsdialog.h
g++ -c -m64 -pipe -fstack-protector-all -D_FORTIFY_SOURCE=2 -O2 -D_REENTRANT -fdiagnostics-show-option -Wall -Wextra -Wformat -Wformat-security -Wno-unused-parameter -Wstack-protector -DQT_WEBKIT -DQT_GUI -DBOOST_THREAD_USE_LIB -DBOOST_SPIRIT_THREADSAFE -DUSE_UPNP=1 -DSTATICLIB -DUSE_IPV6=1 -DHAVE_BUILD_INFO -DLINUX -D_FILE_OFFSET_BITS=64 -DQT_NO_DEBUG -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED -I/usr/share/qt4/mkspecs/linux-g++-64 -I/usr/include/qt4/QtCore -I/usr/include/qt4/QtNetwork -I/usr/include/qt4/QtGui -I/usr/include/qt4 -Isrc -Isrc/json -Isrc/qt -Isrc/leveldb/include -Isrc/leveldb/helpers -Ibuild -Ibuild -o build/bitcoin.o src/qt/bitcoin.cpp
In file included from /usr/include/boost/thread/pthread/mutex.hpp:14:0,
from /usr/include/boost/thread/mutex.hpp:16,
from src/allocators.h:10,
from src/qt/walletmodel.h:8,
from src/qt/bitcoin.cpp:9:
/usr/include/boost/thread/xtime.hpp:23:5: error: expected identifier before numeric constant
/usr/include/boost/thread/xtime.hpp:23:5: error: expected ‘}’ before numeric constant
/usr/include/boost/thread/xtime.hpp:23:5: error: expected unqualified-id before numeric constant
/usr/include/boost/thread/xtime.hpp:38:13: error: ‘int_fast64_t’ does not name a type
/usr/include/boost/thread/xtime.hpp:41:13: error: ‘int_fast32_t’ does not name a type
/usr/include/boost/thread/xtime.hpp:43:5: error: ‘xtime_sec_t’ does not name a type
/usr/include/boost/thread/xtime.hpp:44:5: error: ‘xtime_nsec_t’ does not name a type
/usr/include/boost/thread/xtime.hpp:46:14: error: expected type-specifier before ‘system_time’
/usr/include/boost/thread/xtime.hpp: In function ‘xtime get_xtime(const system_time&)’:
/usr/include/boost/thread/xtime.hpp:64:9: error: ‘struct xtime’ has no member named ‘sec’
/usr/include/boost/thread/xtime.hpp:64:25: error: expected type-specifier
/usr/include/boost/thread/xtime.hpp:64:25: error: expected ‘>’
/usr/include/boost/thread/xtime.hpp:64:25: error: expected ‘(’
/usr/include/boost/thread/xtime.hpp:64:25: error: ‘xtime_sec_t’ is not a member of ‘xtime’
/usr/include/boost/thread/xtime.hpp:64:78: error: expected ‘)’ before ‘;’ token
/usr/include/boost/thread/xtime.hpp:65:9: error: ‘struct xtime’ has no member named ‘nsec’
/usr/include/boost/thread/xtime.hpp:65:26: error: expected type-specifier
/usr/include/boost/thread/xtime.hpp:65:26: error: expected ‘>’
/usr/include/boost/thread/xtime.hpp:65:26: error: expected ‘(’
/usr/include/boost/thread/xtime.hpp:65:26: error: ‘xtime_nsec_t’ is not a member of ‘xtime’
/usr/include/boost/thread/xtime.hpp:65:134: error: expected ‘)’ before ‘;’ token
/usr/include/boost/thread/xtime.hpp: In function ‘int xtime_get(xtime*, int)’:
/usr/include/boost/thread/xtime.hpp:73:40: error: ‘get_system_time’ was not declared in this scope
/usr/include/boost/thread/xtime.hpp:73:40: note: suggested alternative:
In file included from /usr/include/boost/thread/locks.hpp:12:0,
from /usr/include/boost/thread/pthread/mutex.hpp:12,
/usr/include/boost/thread/thread_time.hpp:19:24: note: ‘boost::get_system_time’
/usr/include/boost/thread/xtime.hpp: In function ‘int xtime_cmp(const xtime&, const xtime&)’:
/usr/include/boost/thread/xtime.hpp:82:13: error: ‘const struct xtime’ has no member named ‘sec’
/usr/include/boost/thread/xtime.hpp:82:24: error: ‘const struct xtime’ has no member named ‘sec’
/usr/include/boost/thread/xtime.hpp:83:26: error: ‘const struct xtime’ has no member named ‘nsec’
/usr/include/boost/thread/xtime.hpp:83:37: error: ‘const struct xtime’ has no member named ‘nsec’
/usr/include/boost/thread/xtime.hpp:85:21: error: ‘const struct xtime’ has no member named ‘sec’
/usr/include/boost/thread/xtime.hpp:85:31: error: ‘const struct xtime’ has no member named ‘sec’
/usr/include/boost/thread/xtime.hpp: At global scope:
/usr/include/boost/thread/xtime.hpp:88:1: error: expected declaration before ‘}’ token
make: *** [build/bitcoin.o] Error 1
real 0m0.002s
user 0m0.001s
sys 0m0.001s
