UdjinM6 Official Dash Dev Dash Core Group Dec 12, 2017 #2 You probably disabled wallet backups or trying to mix on a masternode - mixing won't work in either case.
pwjjrn Member Dec 12, 2017 #3 UdjinM6 said: You probably disabled wallet backups or trying to mix on a masternode - mixing won't work in either case. Click to expand... thank you for your help.I did disable the auto backup function.
