On 18 Jan 2016, Evan Duffield proposed a block size limitation increase (see link)[1]: The proposal sought a determination that has dogged bitcoin for some time. The block size was never increased in dash, it was simply a tool to measure MNO sentiment. This proposal is much in the same spirit, to measure sentiment and to send a clear message to the core team.
Previously, Evan Duffield has expressed his view on fungibility (see link)[2]:
...and (see link)[3]:
And thus Evan Duffield's Private Send was born.
Since Evan Duffield made these comments, block chain privacy has increasingly eroded. Indeed, dash itself now has an official compliance partner (Coinfirm) that has two-way relationships with various carriers and exchanges and more. (see their relationships with Bisnode / Vodafone)[4]: and (Bisnode / D&B Germany)[5]: Companies like Coinfirm are building advanced tools to uncover the identities and risks associated with transactions. The net result; not all coins are equal.
Additionally, recent events between Coinbase and the IRS have highlighted significant issues regarding block chain transparency.
Dash is now at a crossroads. In order to find a balance between privacy and transparency we must ask, do you want a transparency-first block chain or a privacy-first block chain?
Vote "Yes" if you would like to see dash switch to a privacy-first block chain (permissioned transparency).
Vote "No" if you want to keep dash's transparency-first block chain (privacy via mixing).
Definition:
Dash is an example of a transparency-first block chain, meaning, all transactions can be easily seen (public) and mixing is used to obfuscate.
Monero, for example, is a privacy-first block chain, meaning, all transactions are obfuscated but can be seen with a view key.
[1]: https://www.dash.org/forum/threads/dash-birthday-trademark-resolution-blocksize-limitation.7696/
[2]: https://medium.com/@simon/the-bright-side-of-darkcoin-a923facddc3c#.w1boqumbz
[3]: https://www.coingecko.com/buzz/interview-evan-duffield-dash
[4]: https://www.bisnode.com/international/news-and-inspiration/cases/vodafone--db-hungary/
[5]: https://www.bisnode.com/international/news-and-inspiration/cases/forbo--hoppenstedt-360/
"I believe the central problem with Bitcoin is that the public ledger, although a remarkable accomplishment, also allows a gross invasion of personal privacy by permanently listing all transactions the users have ever done publicly. I would imagine many groups are working to tie the addresses used to real identities and then following the money around to see what is happening with it.
There was also a lot of talk recently about tainting coins to check and see if they’re “clean” (note: he means colored coins). I believe that all coins should be considered equal and you shouldn’t mess with the fungibility of the coins themselves."
"How do you make a stable environment for it without losing fungibility of the individual coins? How do they expose users to privacy-invasive situations and things like that. I was watching and waiting for the Bitcoin team to do something about the fungibility issue but it never happened.
With Bitcoin, every transaction is traceable back to the coinbase transaction. What that means is that the coinbase is where the actual coins were created - that's when the miner mined them originally and then they start this path through the network from user to user. You can follow this procession and if at any point a user is identified as owning a specific address it suddenly means that anything they do after that is traceable. If you can identify one of the other addresses after it, you know that they did business with that person. The closer that those two transactions are, the more likely this happened.
Eventually a lot of these addresses and users are going to be identified. There will be companies selling these data, which is an invasion of privacy and no one wants a system that is susceptible to those types of attacks especially with a global ledger on the internet."
Definition:
