Platform chain stalled
LustigPenguin
So the platform chain stalled. Here's my report from an evonode.
I tried
Bash:
dashmate status
and the command hung, over ten minutes went by with no output. So I did CTRL C to exit that.
Then
Bash:
dashmate stop
and then
Bash:
dashmate start
The node started up again and resynced. Now
Bash:
dashmate status
does produce an output and reports an error for the platform chain.
@LustigPenguin try do dashmate status again, what Platform Block Height is your node now on, after you did stop - start - resync ? 32328 or 32325 ? And did it resync Platform chain from scratch or just synced up in a few minutes ?
Also verify Core Height please with dashmate status (should be same as here : https://chainz.cryptoid.info/dash/).
Here's the output with some redactions
Network                │ mainnet                                                          ║
║ Core Version           │ 21.1.1                                                           ║
║ Core Status            │ running                                                          ║
║ Core Service Status    │ up                                                               ║
║ Core Size              │ 37.38 GB                                                         ║
║ Core Height            │ 2165466                                                          ║
║ Core Sync Progress     │ n/a                                                              ║
║ Masternode Enabled     │ true                                                             ║
║ Masternode State       │ READY                                                            ║
║ PoSe Penalty           │ 0        ║
║ Platform Enabled       │ true                                                             ║
║ Platform Status        │ error                                                            ║
║ Platform Version       │ n/a                                                              ║
║ Platform Block Height  │ n/a                                                              ║
║ Platform Peers         │ n/a                                                              ║
║ Platform Network       │ n/a                                                              ║
I suspect you are currently stuck at Platform blockheight 32325 (check on https://mnowatch.org/evonodes/), as mine looks like this in dashmate status :
There is currently too few Evonodes on Platform block 32328 (below 100 Evonodes) to keep blocks going, so right now we are both stuck.
So I was still getting an error and i did
Bash:
dashmate reset
Do not recommend as it seems to be re-syncing the core node. I expect that it will catch up to your node @qwizzie eventually though. Might get PoSe banned while I wait, but such is life.
Lets pray all together, for Platform chain to stay stalled forever.
This is a way for Dash to be saved, otherwise Dash will be devoured by this demonic parasite.
The other way for Dash to be saved, is to vote the numbers and reduce the platform rewards.
OK, my node is back up. Game on!
The pray was not strong enough. The daemons regrouped , and managed to revive the Evolution Demolition Platform parasite. Dash community continues to the path of the doom.
I may not have a prayer strong enough to destroy the demolition platform, but my curse against it remains firm. I hope others will also curse it so that the prayer becomes enough strong in order to eliminate this demonic platform and save the Dash community from destruction.
Lets curse the Platform, lets vote the numbers and reduce the platform rewards to almost zero.
I tried
Bash:
dashmate status
Then
Bash:
dashmate stop
and then
Bash:
dashmate start
Bash:
dashmate status
The update is out, go ahead and get v1.5.1
If platform is not working still, then stop platform only, reset platform and start again platform.
