Not Yet Redeemed coins
ArpFlush
Hi all,
Someone send me darkcoins to my wallet but it appears I can't redeem them. I can't post a link yet to the blockchain due to new account.
Meanwhile I reinstalled my wallet (0.11.0.13 on Macbook OSX Yosemite), deleted peers.dat, reindexed but still no coins.
What can I or the sender do more?
Thanks!
Welcome! :)
Well at least these 9 DRKs are on the right chain.
Open Tools -> Console
Type getinfo
Verify that blocks number is the same as here http://explorer.darkcoin.io/chain/Darkcoin
If it's not - -reindex again, if it is - type dumpprivkey XtCSVT2DFLMnJNNQaSWEHRK66hRg8qDTUD
If you get some long string in output - you have private key (and control) for coins (DO NOT SHARE IT, KEEP IT SECRET) so coins should be in your balance once you are synced at least at block 208416.
If you get an error - no luck, it's not your address... or your wallet got corrupted... we'll need more info then.
EDIT: "not yet redeemed" - means it wasn't spent by the receiver yet
https://bitcointalk.org/index.php?topic=421615.msg10249061#msg10249061
ok, BCT is down again so I'll post my reply here too:
Looks like you are on the wrong chain now.
Type in console getblockhash 208423 and compare its output to 0000000000081b93eef2fcac1a1391344699608b12fbd11068450bc12284d99c
If they don't match then you need to reindex again or you might also try to sync using bootstrap method https://github.com/UdjinM6/darkcoin-bootstrap - I just updated it with the latest blockchain data.
https://bitcointalk.org/index.php?topic=421615.msg10249310#msg10249310
Thank you.
Yep, that's me on bitcointalk :)
I deleted peers.dat again, copied bootstrap.dat en reindexed but the result is still the same. Are there other things I can do?
Thanks for your help btw ;)
Thank you.
Update: one minute after sync, the wallet synced the last block and my coins have arrived :)
