My proposal does not appear in DashCentral
Tried submitting the proposal to the network myself using "gobject submit" command. Now I can see the proposal using "gobject list" command so I think it worked. I hope it will appear in DashCentral soon.
I think DashCentral just didn't brodcast the proposal although there was no error message or anything.
Problem fixed now. If you are submitting a proposal using DashCentral then always save every command to a text file so that you can manually submit the proposal if something goes wrong!
