younglegend
my mobile wallet isn't synchronizing for about an hour now...
its still pending... anyone have same problem?
android wallet version 5.14.5
im using galaxy note4
If the Dash Wallet 5.14.5 isn't syncing, its because there are network connectivity issues on the device (perhaps because of WiFi or other things) or it is incorrectly reporting that it is not synced (a bug that happens in rare cases).
If your balance is empty, then perhaps there are network connectivity issues, but it is hard to tell. Did you do a Reset blockchain?
Do a Report Issue from the nav menu and I will look at the logs and try to figure out if there is a problem.
The backup files from this app do not work on any other software. You can over do Safety / View Recovery Phrase and get your 12 word seed phrase that you can import into anothter app that supports BIP32 such as dashwallet for iOS.
Next to the Dash logo, there is a hamburger icon (three horizontal lines on top of each other). Tap that and then Report Issue is the 5th item.
yes, mine has finally synchronised, but is empty of transactions and balance.
and i have wallet backup .dat files, but dash core will not accept the file.
i have checked on dash explorer, chainzID and all the transactions and balance are correct there.
i have done a wallet backup in the past, just to make sure i could do it, if ever i needed to,
and it worked fine then.
wallet.dat backup is now not working.
any clues what to do next.
i have both my PUB and PRIVATE keys to my wallet.
thank you all
PS
just curious, i could not find a forum specifically for dashcore .
could you please make one tungfa and friends?
so that these dash core difficulties, info and solutions are all in one place.
ah hah, perhaps the hamburger is only on a phone wallet?
I reported the issue on android wallet.
thank you guyz for prompt response, it means a world to me.
