Most of the masternodes down, Sentinel problem ? (Fix in thread)
qwizzie
dashninja.pl :
If you guys on Slack or other forums know more about this situation, please keep us in the loop.
git pull in sentinel folder. no restart needed
thanks, for those that are wondering what this means :
cd .dashcore
cd sentinel
git pull
Link : https://www.dash.org/forum/threads/...nel-hotfix-action-required.17568/#post-143923
No restart from cold wallet necessary !
No restart of dashd necessary !
quote from flare :
Technically the nodes are not down, they just failed to vote on a watchdog object.
As a sidenote: Dash 12.2 will not have watchdogs anymore, they are deprecated.
quote from nmarley :
Note: This is required or your Masternode will go offline!
(edit: Apparently w/spork 14 off this isn't enforce, so crisis averted!)
Update : looks like there is a time window after all, masternode owners have 180 minutes to issue a git pull to fix sentinel manually.
Dash Central gave a false warning in the end that my masternodes were disabled, while in fact they are working fine according dashninja.pl and according IP grep (shows ENABLED).
I tried removing my masternodes and re-adding them in Dash Central, but they are now all stuck at status "checking".
Shout-out to : @rango
For some reason sentinel wasn't executable anymore so I made it executable and tried to run it. I got "[error] missing dependencies" So I tried "venv/bin/pip install -r requirements.txt" and every line says "already satisfied".
edit: I did ./sentinel for some reason. When I do ./venv/bin/python bin/sentinel.py I still get no output.
Sentinel should not be executed, it must be interpreted in a virtual environment. If you run /venv/bin/python bin/sentinel.py and get no output, then everything is working perfectly and your masternode is alive, online and recognised by the network.
Even if list full | grep returns WATCHDOG_EXPIRED?
Did you do a git pull for sentinel ? The git pull updates sentinel to 1.0.2
and includes a hotfix for the watchdog expired issue.
Also make sure you have the cronjob for sentinel running...
