How to restart masternode on a pc ?
Hi
I have read instructions on building and commissioning a masternode on a windows pc,, what I want to know is:-
if the pc were to crash whilst the masternode is running!! Do I simply restart the pc then the wallet in order to get the masternode running again or is there some additional masternode restart procedure ??
cheers
Hello, are you running the masternode on your (hot) local PC?
Well :) no, your local wallet can be shut down once you start the node from local, all you need to do is to setup the remote side.
Check my signature for more info if you need the service for that.
