How to donate ?
first, you need a 'start-many' config that uses the 'masternode.conf' file
then, to the end of your masternode.conf line (right after the output index integer) add: destinationaddress:percentage
e.g. <alias> <mnaddr> <mnprivkey> <txid> <vout> Xblahblahblahblah:10
to send, on average, one out of every 10 masternode block reward payments to Xblahblahblahblah
note: block reward payments are not split into two outputs.
payments are redirected to the donation address on a schedule defined by the percentage /on average/
This is great
And I belive we are the 1st crypto which maintains development and network by decentralised donations !
Still a bit complicate for me but will seek some pro help to get this sorted out
Tx for the advice
